Ir para o conteúdo principal
FirsTime Wall Clock Movemement Mechanism Replacement
O que você precisa
  1. FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: passo 1, imagem 1 %32 FirsTime Wall Clock Movemement Mechanism  Replacement, Movemement Mechanism: passo 1, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove all four screws on the back of the clock.
  2. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 2, imagem 1 %32
    • Once screws are removed, simply remove the glass lens covering the display of the clock by lifting it with your hands.
  3. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 3, imagem 1 %32 FirsTime Wall Clock Movemement Mechanism  Replacement: passo 3, imagem 2 %32
    • Turn the display face up.
    • Use needle nose pliers to pull off the 'second' hand.
  4. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 4, imagem 1 %32 FirsTime Wall Clock Movemement Mechanism  Replacement: passo 4, imagem 2 %32
    • Use needle nose pliers to remove the 'minute' hand.
    • Then use needle nose pliers to remove the 'hour' hand.
  5. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 5, imagem 1 %32
    • Once all hands are removed, use a 7/16-inch wrench to unscrew, in counter clockwise direction, the threaded nut in the center of the clock.
    • Removing the threaded nut is what allows the movement mechanism to be removed from the clock.
  6. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 6, imagem 1 %32 FirsTime Wall Clock Movemement Mechanism  Replacement: passo 6, imagem 2 %32
    • Lift the washer underneath the nut with your fingers.
  7. FirsTime Wall Clock Movemement Mechanism  Replacement: passo 7, imagem 1 %32
    • Now you may remove the display of the clock from your malfunctioning movement mechanism.
Conclusão
25 outras pessoas executaram este guia.
7Comentários do guia
Is there a you tube showing these steps?
Patricia Ander - Responder
Thank you! there was one tricky thing—the parts I got in the order did not match what I took off, so I had to reconfigure it a bit per new instructions that came with the parts. But I figured it out! Thank you for this instruction.
Leslie Benitez - Responder
Excellent illustrations!!!
KO SAMUEL TAK SHUN - Responder
there seem to be 2 projections keeping the back & glass together.
I don't want to break them.
Marcia Kaminski - Responder
Where can I buy the exact clock?
Barb - Responder
Comentar
Visualizações:
Últimas 24 horas: 12
Últimos 7 dias: 51
Últimos 30 dias: 183
Ao todo: 12,604
