Ir para o conteúdo principal
Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW
O que você precisa
  1. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW, Filter Housing for GE Refrigerators: passo 1, imagem 1 %32
    • Disconnect the electric plug from the wall.
  2. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 2, imagem 1 %32
    • Turn off or push down off water main valve from the wall.
  3. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, imagem 1 %32 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, imagem 2 %32 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 3, imagem 3 %32
    • Remove the back panel with 6 screws from the back panel using a 8 mm nut driver.
  4. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 4, imagem 1 %32 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 4, imagem 2 %32
    • Disconnect the water supplied line from the refrigerator using two 13 mm open-end wrenches.
    • Use a little bucket to receive the water from the water lines.
  5. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 5, imagem 1 %32
    • Disconnect the water line from the water inlet valve using and open-end wrench size 15mm
  6. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 6, imagem 1 %32 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 6, imagem 2 %32
    • Disconnect the water line cover removing 2 screws using a 7 mm nut driver.
    • Pull up the gum seal compound.
  7. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 7, imagem 1 %32
    • Push the left side of the filter cover and pull it straight out.
  8. Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 8, imagem 1 %32 Filter Housing Replacement for GE Refrigerators model GSS25KSW / GSF25KGW: passo 8, imagem 2 %32
    • Remove the 2 screws on top of the housing using 7 mm nut driver.
    • Pull the housing and filter out slowly.
    • Remove the filter by turn it counterclockwise
Conclusão
Giancarlo Marruffo
Membro desde: 09/18/16
2 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 2,090
