Ir para o conteúdo principal
Fiat 500 Abarth Taillight Replacement
O que você precisa
  1. Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: passo 1, imagem 1 %32 Fiat 500 Abarth Taillight Replacement, Fiat 500 Abarth Taillight: passo 1, imagem 2 %32
    • Remove the two 10 mm bolts to the side of the taillight.
  2. Fiat 500 Abarth Taillight Replacement: passo 2, imagem 1 %32 Fiat 500 Abarth Taillight Replacement: passo 2, imagem 2 %32
    • Using a pry tool or something flat, carefully get in-between the light and the car and pry the light off.
    • The light still has cable connections to the car body, so be sure not to rip these during removal.
  3. Fiat 500 Abarth Taillight Replacement: passo 3, imagem 1 %32 Fiat 500 Abarth Taillight Replacement: passo 3, imagem 2 %32 Fiat 500 Abarth Taillight Replacement: passo 3, imagem 3 %32
    • There are several little clips on this module.
    • Unclip the clips on the back of the light and remove the panel.
  4. Fiat 500 Abarth Taillight Replacement: passo 4, imagem 1 %32 Fiat 500 Abarth Taillight Replacement: passo 4, imagem 2 %32 Fiat 500 Abarth Taillight Replacement: passo 4, imagem 3 %32
    • Remove the burnt out bulb by pulling it out from the panel.
  5. Fiat 500 Abarth Taillight Replacement: passo 5, imagem 1 %32 Fiat 500 Abarth Taillight Replacement: passo 5, imagem 2 %32 Fiat 500 Abarth Taillight Replacement: passo 5, imagem 3 %32
    • Clip the panel back onto the light and put it back into the frame of the car.
    • Replace the two bolts with a 10 mm socket.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 64
Últimos 30 dias: 260
Duração total: 10,481
