Ir para o conteúdo principal
Bomann DB 774CB Iron
O que você precisa
  1. Bomann DB 774CB Iron, Startup: passo 1, imagem 1 %32
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: passo 2, imagem 1 %32 Bomann DB 774CB Iron, Undressing the handle: passo 2, imagem 2 %32 Bomann DB 774CB Iron, Undressing the handle: passo 2, imagem 3 %32
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: passo 3, imagem 1 %32 Bomann DB 774CB Iron, Stripping of the sole: passo 3, imagem 2 %32
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: passo 4, imagem 1 %32
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Conclusão
Putting each screw back in its place is no problem.
6 outras pessoas executaram este guia.
Um agradecimento especial a esses tradutores:
fr en
100%
HelloMacOS está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Louis Possoz
Membro desde: 01/10/15
435 Reputação
Autoria de 3 guias
Equipe
Repair Café Louvain-la-Neuve Membro de Repair Café Louvain-la-Neuve
Repair Café
Membros da 2
Autoria de 6 guias
Um comentário
Do you instructions in English
Nur Haque - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 36
Duração total: 2,934
