Ir para o conteúdo principal
Fender Starcaster Tuning Heads Replacement
O que você precisa
  1. Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, imagem 1 %32 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, imagem 2 %32 Fender Starcaster Tuning Heads Replacement, Loosen the Strings: passo 1, imagem 3 %32
    • Start by loosening the strings. This is done by turning the tuning knob until the string has lost tension.
    • Repeat this for all six strings on the guitar.
  2. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: passo 2, imagem 1 %32 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Tuning Pegs: passo 2, imagem 2 %32
    • Be mindful of the string ends. They may be sharp and could puncture your skin.
    • It may be necessary to use pliers to remove string ends from the tuning peg.
  3. Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, imagem 1 %32 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, imagem 2 %32 Fender Starcaster Tuning Heads Replacement, Remove the Strings from the Bridge: passo 3, imagem 3 %32
    • After removing the strings from the tuning pegs, slide the strings through the bridge and out of the back of the guitar.
    • If the twists in the string ends are in the way, use wire cutters to snip them off. This will allow the heavier strings to pass through the bridge easier.
    When I cut 4-6 winding string, I have experience with the metal piece of the string entering my eyeball.
    It is recommended to wear goggles or cut with eyes closed.
    Takehiro - Responder
  4. Fender Starcaster Tuning Heads Replacement, Tuning Heads: passo 4, imagem 1 %32 Fender Starcaster Tuning Heads Replacement, Tuning Heads: passo 4, imagem 2 %32
    • Using a wrench, remove the nuts around each tuning head post.
  5. Fender Starcaster Tuning Heads Replacement: passo 5, imagem 1 %32 Fender Starcaster Tuning Heads Replacement: passo 5, imagem 2 %32 Fender Starcaster Tuning Heads Replacement: passo 5, imagem 3 %32
    • Next, remove the threaded retainer sleeve from each post.
    • Don't forget the washer.
  6. Fender Starcaster Tuning Heads Replacement: passo 6, imagem 1 %32 Fender Starcaster Tuning Heads Replacement: passo 6, imagem 2 %32
    • Next, remove the screws from the backside of each tuner.
  7. Fender Starcaster Tuning Heads Replacement: passo 7, imagem 1 %32 Fender Starcaster Tuning Heads Replacement: passo 7, imagem 2 %32
    • Finally, remove the tuning machine assembly from the headstock.
Conclusão
Equipe
Pasco Hernando, Team 5-3, Prince Fall 2014 Membro de Pasco Hernando, Team 5-3, Prince Fall 2014
PHSC-PRINCE-F14S5G3
Membros da 9
Autoria de 10 guias
3 comentários
Does the 2013 Starcaster take a 10mm tuning peg?
Brian Seese - Responder
This is only the removal. Nothing After step 7. What about the actual replacement? What did you replace them with? Did it involve any machining?
Richard Caruso - Responder
This is only the removal. What about the actual replacement? What did you replace them with? Did it involve any machining?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 28
Duração total: 2,469
