Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
O que você precisa
Use a Phillips #0 screwdriver to remove the four 21.7mm screws holding the back panel to the frame.
There will be two black wires connecting the top mounting bracket to the reverb box at the bottom of the unit. Label the wires to prevent crossing upon re-installation, then unplug the wires from the reverb box.
Once the old bracket is removed, install the new one by following the instructions in reverse.
