Ir para o conteúdo principal
Fender 68 Custom Deluxe Reverb Speaker Replacement
O que você precisa
  1. Fender 68 Custom Deluxe Reverb Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Lay the amplifier face-down.
  2. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 2, imagem 1 %32
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 3, imagem 1 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 3, imagem 2 %32
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 4, imagem 1 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 4, imagem 2 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 4, imagem 3 %32
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 5, imagem 1 %32
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 6, imagem 1 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 6, imagem 2 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 6, imagem 3 %32
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 7, imagem 1 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 7, imagem 2 %32 Fender 68 Custom Deluxe Reverb Speaker Replacement: passo 7, imagem 3 %32
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 96
