Ir para o conteúdo principal
Felt Z85 Brake Pad Replacement
O que você precisa
  1. Felt Z85 Brake Pad Replacement, Remove Wheel: passo 1, imagem 1 %32 Felt Z85 Brake Pad Replacement, Remove Wheel: passo 1, imagem 2 %32 Felt Z85 Brake Pad Replacement, Remove Wheel: passo 1, imagem 3 %32
    • Pull up on brake-release lever to spread pads for easy access.
    • Release lever on the right side of the wheel.
    • Loosen left nut on wheel until wheel comes free.
  2. Felt Z85 Brake Pad Replacement, Remove Pad(s): passo 2, imagem 1 %32 Felt Z85 Brake Pad Replacement, Remove Pad(s): passo 2, imagem 2 %32 Felt Z85 Brake Pad Replacement, Remove Pad(s): passo 2, imagem 3 %32
    • Locate Brake Caliper.
    • Use 4.0 mm allen key to remove main bolt.
    • Rotate counterclockwise to loosen.
    • Be careful not to lose both the washer and spacer found in-between the bolt and the brake pad mounting hole.
    • Repeat step 2 to remove the pad on the other side.
  3. Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): passo 3, imagem 1 %32 Felt Z85 Brake Pad Replacement, Collecting parts (reinstall): passo 3, imagem 2 %32
    • Brake Pad: The item being replaced.
    • Spacer: This item will be reused.
    • Washer: This item will be reused.
    • 4 mm hex bolt.
    • Note order of mounting hardware for reinstall.
Conclusão
Ryan Marschall
Membro desde: 10/11/14
123 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-21, Donnelly Fall 2014 Membro de USF Tampa, Team 1-21, Donnelly Fall 2014
USFT-DONNELLY-F14S1G21
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 1,038
