Introdução
This guide will show the procedure on how to completely replace the bike seat and seat slider on the Peloton Bike+ by removing the seat and slider, and replacing it with a new one. It is a fairly simple process that people with little to no experience in repairing things should be able to do.
Note: This guide is for the Peloton Bike+, not the base Peloton Bike. Both bikes are similar, but some mechanisms are a bit different.
If there are other issues with your bike, the Peloton Support Page contains much repair information that may be useful to you.
The tools needed for this guide are included in the toolkit that comes with the Peloton bike. Those tools are:
- A 13mm Wrench
- A 3mm Allen Wrench
Now lets get fixing shall we?
O que você precisa
Remove any weights or other items from the weight holders. Also, make sure there is nothing on the bike seat itself.
If you notice anything off with the new bike seat and slider, make sure that everything is secure and all screws/nuts are tight. If you still notice issues, simply follow the guide again, but do not replace any parts with new parts, just remove and replace those same parts.
