Ir para o conteúdo principal
Ovation Acoustic Guitar String Replacement
O que você precisa
  1. Ovation Acoustic Guitar String Replacement, Guitar String: passo 1, imagem 1 %32
    • Place the guitar neck where you can easily identify the broken string.
  2. Ovation Acoustic Guitar String Replacement: passo 2, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 2, imagem 2 %32
    • Place the guitar neck on an elevated surface (ex. bundle towels, pillow, etc.). Remove the string with a string winder until it is loose enough to pull out by hand.
  3. Ovation Acoustic Guitar String Replacement: passo 3, imagem 1 %32
    • Take the string out carefully and begin to pull the string out through the bridge which is at the lower end of the guitar.
  4. Ovation Acoustic Guitar String Replacement: passo 4, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 4, imagem 2 %32
    • Once the string is removed, wipe down the guitar neck to prevent further oil buildup.
  5. Ovation Acoustic Guitar String Replacement: passo 5, imagem 1 %32
    • Layout the new guitar strings from biggest to smallest.
  6. Ovation Acoustic Guitar String Replacement: passo 6, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 6, imagem 2 %32 Ovation Acoustic Guitar String Replacement: passo 6, imagem 3 %32
    • Pull the new string through the bridge until the stopper is flushed with the bridge.
  7. Ovation Acoustic Guitar String Replacement: passo 7, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 7, imagem 2 %32
    • Position the skinny side of the string into the tuning peg. Allow enough excess string ( about 3 inches) so when the string is tightened, it will not break from being too tight or break from being too loose.
  8. Ovation Acoustic Guitar String Replacement: passo 8, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 8, imagem 2 %32 Ovation Acoustic Guitar String Replacement: passo 8, imagem 3 %32
    • Loop the excess guitar string around the tuning peg and make sure the coil is being tuned downwards.
  9. Ovation Acoustic Guitar String Replacement: passo 9, imagem 1 %32 Ovation Acoustic Guitar String Replacement: passo 9, imagem 2 %32
    • Trim the excess string with pliers. Make sure it is cut as close to the tuning peg so it does not stick out.
Linha de Chegada
Rachel Galvan
Membro desde: 04/07/21
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 23
Duração total: 708
