Ir para o conteúdo principal
2005 Jeep Liberty Fog Light Replacement
O que você precisa
  1. 2005 Jeep Liberty Fog Light Replacement, Fog Light: passo 1, imagem 1 %32
    • Open the hood to access the radiator grill tabs.
    • Pull up on the first tab and repeat for the remaining four tabs.
  2. 2005 Jeep Liberty Fog Light Replacement: passo 2, imagem 1 %32
    • Tilt the radiator grill cover forward and lift up and out to remove.
  3. 2005 Jeep Liberty Fog Light Replacement: passo 3, imagem 1 %32
    • Using an allen wrench, turn the tension screw counter-clockwise to loosen the light housing.
  4. 2005 Jeep Liberty Fog Light Replacement: passo 4, imagem 1 %32
    • Lift up on the tension screw to release the light housing.
  5. 2005 Jeep Liberty Fog Light Replacement: passo 5, imagem 1 %32
    • Using a flat-head screwdriver, pull the tab outward to remove the light housing.
    • Repeat the procedure for the right side of the light housing.
  6. 2005 Jeep Liberty Fog Light Replacement: passo 6, imagem 1 %32
    • Pull the light housing toward you.
  7. 2005 Jeep Liberty Fog Light Replacement: passo 7, imagem 1 %32
    • Remove the wiring harness from the light socket by lifting up on the tab with a flat-head screwdriver.
  8. 2005 Jeep Liberty Fog Light Replacement: passo 8, imagem 1 %32
    • Remove the light socket from the light housing by turning counter-clockwise.
  9. 2005 Jeep Liberty Fog Light Replacement: passo 9, imagem 1 %32
    • Remove the light socket from the light housing and replace.
    • The light socket part number is 9145 and can be purchased at any auto parts store.
    • Install the new light socket back into the light housing by turning clockwise.
    • Plug the wiring harness back in the light socket.
Conclusão
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
2 comentários
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
vievie aryanti - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 31
Duração total: 7,250
