Ir para o conteúdo principal
Fast Fix Ceiling Clip Mount Light Bulb Replacement
O que você precisa
  1. Fast Fix Ceiling Clip Mount Light Bulb Replacement, Ceiling Clip Mount Light Bulb: passo 1, imagem 1 %32 Fast Fix Ceiling Clip Mount Light Bulb Replacement, Ceiling Clip Mount Light Bulb: passo 1, imagem 2 %32
    • Turn off the electrical circuit breaker and the light switch.
  2. Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 2, imagem 1 %32 Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 2, imagem 2 %32
    • Carefully pull the clip and remove the mount.
  3. Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 3, imagem 1 %32
    • Unscrew the light bulb’s electrical foot contact from the socket.
  4. Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 4, imagem 1 %32 Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 4, imagem 2 %32
    • Carefully screw the new light bulb into the socket.
  5. Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 5, imagem 1 %32
    • Turn the light switch and the circuit breaker back on to check if the light bulb(s) are working before putting the mount cover back on.
  6. Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 6, imagem 1 %32 Fast Fix Ceiling Clip Mount Light Bulb Replacement: passo 6, imagem 2 %32
    • Once the light bulb(s) are working, place one hand under the mount. Pull the clip back and let it settle in place.
Conclusão
If the lightbulb does not work after step 7, then you need to get a new lightbulb and repeat step 5-7. If it still does not work then your socket might need a replacement.
Linh Pham
Membro desde: 01/16/23
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 640
