Ir para o conteúdo principal
Fast Fix Box Cutter Blade Replacement
O que você precisa
  1. Fast Fix Box Cutter Blade Replacement, Blade: passo 1, imagem 1 %32 Fast Fix Box Cutter Blade Replacement, Blade: passo 1, imagem 2 %32 Fast Fix Box Cutter Blade Replacement, Blade: passo 1, imagem 3 %32
    • The case screw can easily be removed by using a Stanley #2 screwdriver or any other #2 screwdriver.
  2. Fast Fix Box Cutter Blade Replacement: passo 2, imagem 1 %32
    • Separate casing by simply pulling apart both halves.
  3. Fast Fix Box Cutter Blade Replacement: passo 3, imagem 1 %32 Fast Fix Box Cutter Blade Replacement: passo 3, imagem 2 %32
    • Carefully, using the pull tab, take out the blade holder and set it on the table.
    • Remove the blade by carefully sliding it out of the holder.
    • Be very careful when dealing with the blade as it is sharp.
  4. Fast Fix Box Cutter Blade Replacement: passo 4, imagem 1 %32 Fast Fix Box Cutter Blade Replacement: passo 4, imagem 2 %32
    • Replace the old blade with the new blade by carefully sliding it into the blade holder.
    • Place the blade holder back into the casing using the pull tab to hold it.
  5. Fast Fix Box Cutter Blade Replacement: passo 5, imagem 1 %32 Fast Fix Box Cutter Blade Replacement: passo 5, imagem 2 %32
    • Add grease to the sliding mechanism
    • Use either a paper towel or a cloth to spread the grease around the sliding mechanism.
  6. Fast Fix Box Cutter Blade Replacement: passo 6, imagem 1 %32 Fast Fix Box Cutter Blade Replacement: passo 6, imagem 2 %32
    • Take the other half without the blade and put it back together with the other half with the blade.
    • Snap the two parts together.
    • Place the screw back in to hole while holding the casing together.
  7. Fast Fix Box Cutter Blade Replacement: passo 7, imagem 1 %32 Fast Fix Box Cutter Blade Replacement: passo 7, imagem 2 %32
    • Use Stanley #2, or any other #2, screwdriver to screw the casing back together.
    • To ensure proper placement of the blade, activate the mechanism that slides the blade out.
    • Once it comes out, like in second picture, you are done.
Conclusão
Peace Adeyemo
Membro desde: 02/22/18
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 42
Duração total: 8,881
