Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
The second step is to take out the little screw on the back side of the key.
You will push the buttons from the front side to have the middle piece fall out.
Then you will unclip the middle part. There is one clip on each side of this piece. They are super fragile and can break easily.
Then push the buttons from the front side to push out a rubber insert.
Then peel out the mother chip and replace your rubber insert.
2 comentários
How do you remove the key from broken fob and put in new fob so you don’t have to incur the cost of cutting new key?
Just open the fob, like in this tutorial. The key is just a piece of metal.
Then place the key in a new fob (or replace only the fob plastic case for a cheaper solution).
Brendan -
