Ir para o conteúdo principal
Fan Replacement
O que você precisa
  1. Fan Replacement, Fan/Heat Sink: passo 1, imagem 1 %32
    • Remove all the screws that hold the plastic bottom cover on. There are some more screws that cant be seen in the photo.
  2. Fan Replacement: passo 2, imagem 1 %32
    • Once screws are removed, remove the back cover.
  3. Fan Replacement: passo 3, imagem 1 %32
    • Encased in red is the area where we are working on
  4. Fan Replacement: passo 4, imagem 1 %32 Fan Replacement: passo 4, imagem 2 %32
    • Locate the two strips of cables projecting from the fan to the white holders circled in red.
    • Using your hand carefully remove the two strips of cables from the white sockets. Preferably grabbing the strip by the head(the white section where the cables are engulfed). If unable to gingerly pull on the cables.
    • Make care to not rip the connectors and the cables
  5. Fan Replacement: passo 5, imagem 1 %32
    • Unscrew the four screws surrounding the heat sink.
  6. Fan Replacement: passo 6, imagem 1 %32
    • You are now clear for liftoff. The fan may fly freely.
    • Now is a prime time to reapply thermal paste if necessary.
Conclusão
Uma outra pessoa concluiu este guia.
Eric Martinez
Membro desde: 02/14/17
637 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 20-5, Remmell Spring 2017 Membro de USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Duração total: 497
