Introdução
Use this guide to replace the broken blade arm of a ceiling fan. A broken ceiling fan can reduce the comfort of your home, and it might make you utilize your home’s air conditioner (AC) more. A working ceiling fan will save money and potentially reduce greenhouse gases that hurt the earth.
Before using this guide, make sure you know where the circuit breaker is located and turn it off for safety reasons. A few necessary tools are needed, and no prior knowledge is required.
O que você precisa
Make sure no power is flowing to the fan. Then begin by removing the metal light frame by twisting.
4Comentários do guia
Where did you bought the replacement for that specific fan I’m looking for the arm and blades with the star
I am as well and harbor breeze and Lowe's are absolutely no help!
Where can I find an exact replacement.
