Ir para o conteúdo principal
Fairphone 4 Screen Replacement
O que você precisa
  1. Fairphone 4 Screen Replacement, Pry the back cover up: passo 1, imagem 1 %32 Fairphone 4 Screen Replacement, Pry the back cover up: passo 1, imagem 2 %32
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Screen Replacement: passo 2, imagem 1 %32 Fairphone 4 Screen Replacement: passo 2, imagem 2 %32 Fairphone 4 Screen Replacement: passo 2, imagem 3 %32
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Screen Replacement: passo 3, imagem 1 %32 Fairphone 4 Screen Replacement: passo 3, imagem 2 %32 Fairphone 4 Screen Replacement: passo 3, imagem 3 %32
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Screen Replacement: passo 4, imagem 1 %32 Fairphone 4 Screen Replacement: passo 4, imagem 2 %32 Fairphone 4 Screen Replacement: passo 4, imagem 3 %32
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Screen Replacement, Lever up the Battery: passo 5, imagem 1 %32 Fairphone 4 Screen Replacement, Lever up the Battery: passo 5, imagem 2 %32 Fairphone 4 Screen Replacement, Lever up the Battery: passo 5, imagem 3 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Screen Replacement, Unscrew the display: passo 6, imagem 1 %32
    • Remove the eight 4.8 mm-long Phillips screws.
  7. Fairphone 4 Screen Replacement, Create a gap: passo 7, imagem 1 %32 Fairphone 4 Screen Replacement, Create a gap: passo 7, imagem 2 %32 Fairphone 4 Screen Replacement, Create a gap: passo 7, imagem 3 %32
    • Flip the phone over so the screen faces up
    • Insert an opening pick between the screen and the frame.
  8. Fairphone 4 Screen Replacement, Slide along the edge: passo 8, imagem 1 %32 Fairphone 4 Screen Replacement, Slide along the edge: passo 8, imagem 2 %32
    • Slide the opening pick along the edge to the top right corner.
  9. Fairphone 4 Screen Replacement: passo 9, imagem 1 %32 Fairphone 4 Screen Replacement: passo 9, imagem 2 %32
    • Continue to slide the opening pick along the top of the phone.
  10. Fairphone 4 Screen Replacement: passo 10, imagem 1 %32 Fairphone 4 Screen Replacement: passo 10, imagem 2 %32 Fairphone 4 Screen Replacement: passo 10, imagem 3 %32
    • Slide the opening pick along the left side to the bottom left corner.
  11. Fairphone 4 Screen Replacement, Flip the screen over: passo 11, imagem 1 %32 Fairphone 4 Screen Replacement, Flip the screen over: passo 11, imagem 2 %32 Fairphone 4 Screen Replacement, Flip the screen over: passo 11, imagem 3 %32
    • Do not remove the screen yet. It's still connected to the phone with a connection cable.
    • Grab the screen and lift it straight up just enough to clear its pegs from the frame.
    • Rotate the display carefully clock-wise and flip it over to get access to the connector.
    • Place the display on the device with the screen facing downwards.
  12. Fairphone 4 Screen Replacement, Disconnect the cable: passo 12, imagem 1 %32 Fairphone 4 Screen Replacement, Disconnect the cable: passo 12, imagem 2 %32
    • Use an opening pick to pry up and disconnect the display connection cable.
    • Remove the screen.
    • Compare your new replacement screen to the original part—you may need to remove a front camera dust cover before you install it.
Conclusão
10 outras pessoas executaram este guia.
Manuel Haeussermann
Membro desde: 07/13/22
15.487 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.767 guias
8 comentários
20-40 Minutes? ... more like 10 ... and I wasn't even pushing it
Patrick Küster - Responder
Thanks for your comment! The time estimate was set a little too high, you're right. I've adjusted it!
Manuel Haeussermann -
Vielen Dank für die präzise Anleitung. Auf alle heiklen Punkte wurde hingewiesen. Habe es locker geschafft und war danach ganz stolz!
Johanna - Responder
I can confirm that you need a #0 screwdriver, not a #00, as has been changed in the latest unchecked version.
Jonathan - Responder
Hi Jonathan, thanks for you comment! While a #0 screwdriver will work, we recommend a #00 as Fairphone themselves do, see their website: "The only tool you will need is a Phillips #00 screwdriver to access all spare parts of the Fairphone 4."
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 21
Últimos 7 dias: 135
Últimos 30 dias: 413
Duração total: 10,739
