Ir para o conteúdo principal
Fairphone 4 Earpiece Speaker Replacement
O que você precisa
  1. Fairphone 4 Earpiece Speaker Replacement, Pry the back cover up: passo 1, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Pry the back cover up: passo 1, imagem 2 %32
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Earpiece Speaker Replacement: passo 2, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement: passo 2, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement: passo 2, imagem 3 %32
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Earpiece Speaker Replacement: passo 3, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement: passo 3, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement: passo 3, imagem 3 %32
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Earpiece Speaker Replacement: passo 4, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement: passo 4, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement: passo 4, imagem 3 %32
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Earpiece Speaker Replacement, Lever up the Battery: passo 5, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Lever up the Battery: passo 5, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement, Lever up the Battery: passo 5, imagem 3 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Earpiece Speaker Replacement, Unscrew the cable cover: passo 6, imagem 1 %32
    • Remove the 4.8 mm-long Phillips screw.
  7. Fairphone 4 Earpiece Speaker Replacement, Remove the cable cover: passo 7, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Remove the cable cover: passo 7, imagem 2 %32
    • Insert an opening pick beneath the cover near the triangular mark.
    • Twist the opening pick to pry the cover up.
    • Remove the cover.
  8. Fairphone 4 Earpiece Speaker Replacement, Disconnect cables: passo 8, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Disconnect cables: passo 8, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement, Disconnect cables: passo 8, imagem 3 %32
    • Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
  9. Fairphone 4 Earpiece Speaker Replacement: passo 9, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement: passo 9, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement: passo 9, imagem 3 %32
    • Lift up the right connector to reveal the additional connector beneath it.
    • Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
  10. Fairphone 4 Earpiece Speaker Replacement, Unscrew the rear camera module: passo 10, imagem 1 %32
    • Remove the five 4.8 mm-long Phillips screws.
  11. Fairphone 4 Earpiece Speaker Replacement: passo 11, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement: passo 11, imagem 2 %32 Fairphone 4 Earpiece Speaker Replacement: passo 11, imagem 3 %32
    • Use an opening pick to slide underneath the rear camera module.
    • Slide the opening pick along the rear camera module to release the clips that hold it in place.
  12. Fairphone 4 Earpiece Speaker Replacement: passo 12, imagem 1 %32
    • Lift the rear camera module and remove it.
  13. Fairphone 4 Earpiece Speaker Replacement, Disconnect the earpiece speaker cable: passo 13, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Disconnect the earpiece speaker cable: passo 13, imagem 2 %32
    • Use a spudger to disconnect the earpiece speaker by prying the connector straight up from its socket.
  14. Fairphone 4 Earpiece Speaker Replacement, Remove the earpiece speaker: passo 14, imagem 1 %32 Fairphone 4 Earpiece Speaker Replacement, Remove the earpiece speaker: passo 14, imagem 2 %32
    • Use a spudger to lift the earpiece speaker so you can grab it.
    • Remove the earpiece speaker.
Conclusão
Manuel Haeussermann
Membro desde: 07/13/22
15.369 Reputação
Autoria de 71 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.718 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 913
