Introdução
Use this guide to remove or replace a broken or defective display module in your Fairphone 3.
O que você precisa
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Remove the thirteen Phillips #00 screws (4 mm length).
vis M 1.4/4 mm
Insert an opening pick between the midframe and the display module on the right edge of the phone.
Slide the opening pick down to the bottom right corner to pry open the plastic clamps of the display module.
Hello. I do not have an opening pick; one was not provided with the telephone or the camera module. How am I supposed to install the item if I have not been either provided with, or informed of the requirement for, a necessary tool? This makes it extremely difficult for a customer to make their own installations or repairs. Also, I do not have a spudger, and I had to look up what a spudger is. These are not everyday items found in most people’s toolboxes, so I feel that they should be provided, or a warning should be given when buying items (such as the camera module) which will require additional tools to install.
Hi, you are right, there should be a hint to buy those tools. Maybe you have a guitar pick or a very thin spatula or putty knife. It is better to not use metal, to not damage the frame, but if you have no other tool this may help.
Attention de bien insérer sur la rainure la plus à l'extérieur, vous allez sinon decoller le joint fixant l'écran à proprement parler au reste du module.
Si ça vous arrive, vous le saurez en voyant que la partie décollée est toujours reliée par une nappe à la partie inférieure de l'écran. Pas de panique, appliquez quelques points de colle par dessus le joint d'origine et recommencez la procédure, cette fois dans la bonne rainure (et la procédure devrait vous paraître beaucoup plus simple ;) )
Punaise, moi cette partie de mon écran se décolle toute seule. Juste un tout petit peu, par le haut. Vous me conseillez de le décoller plus pour pouvoir y mettre de la colle ?? Quelle colle serait le mieux ? (pas envie d’acheter un écran vu que le mien fonctionne très bien quand même)
Hello, I got frustrated when I didn’t find any opening pick. I’m not a guitarr player either ;-) , so I took a old credit card instead. It worked fine! I got a spudger when I bought the FP3.
Anyway, these tools are not common in most households, so they should be provided or at least they should be hinted that they are needed.
Hey, I cut the edge off a stiff plastic packaging and inserted it. It was itself too wobbly, but widened the gap enough so I could insert the edge of a credit card which worked just fine.
Ich hatte kein Plektrum habe es mit einer Chip-Karte probiert, das ging auch.
Slide the opening pick around the bottom right corner and use it to disengage the plastic clamps at the bottom of the display module.
Hallo
nachdem mein Handy ausversehen runtergefallen ist, war das Display dunkel; ein/aus half nichts, akku raus/rein auch nicht. Es gab Brumgeräusche wie beim Starten wenn ich Start gedrückt habe, das Display blieb dunkel. Ich konnte das Display mit etwas mühe(ungeübt) ausbauen und wieder einbauen. Danach ging es wieder; Danke euch hier für die Anleitung. So ein Plektrum habe ich leider nicht mehr, ich glaub es war eines dabei. Ich habe mir mit einem kleinen Plastiklöffel geholfen, der ist jetzt mein Star :-)
Sehr gut! Viel Spaß mit deinem Fairphone!
Remove the display assembly.
ATTENTION !l’écran neuf comprend un cache plastique qui tient avec 2 vis ! pour monter le nouvel écran il faut dévisser les vis et enlever le cache plastique
Die weiße Plastikabdeckung an dem neuen Modul muss vor dem Einbau noch gelöst werden (2 Schrauben).
Vielen Dank für die kleinschrittige Anleitung, dir mir als Reparaturmuffel geholfen hat, mein Handy wieder zu aktivieren. Hintergrund: nach einem Sturz war das Display total verpixelt. Durch aus- und Einbau des Displays wurden die durch den Sturz gelockerten Kontakte wieder neu verbunden und - siehe da - es funktioniert wieder alles wie am ersten Tag! Da bin ich froh, daß ich mich für ein fairphone entschieden habe.
Sehr gut! Weiter viel Spaß mit deinem Fairphone!
39 outras pessoas executaram este guia.
19 comentários
Bonjour,
Mon écran est noir depuis une chute, mais il n’y a aucun impact.
Je voudrais bien le changer, mais comment être sure que le problème ne vient que de l’écran? A 90e la pièce, ça m’embêterait de me tromper de problème… Merci de votre aide
Bonjour,
Je suppose que depuis ce temps là vous avez trouvé une solution…
Mais, à toute fin utile dans cette page, le démontage (nettoyage des contacts) remontage a permis de refaire fonctionner l’écran d’un FAIRPHONE3 qui ne répondait plus au toucher !
La déconnexion-reconnexion de la carte mère y est aussi peut-être pour quelque chose…
Marette -
Wichtig: beim Lösen der Klammern der Displayeinheit muss dass Plektrum in die Rille zwischen äusserem Rand und dem Rand der Einheit gesteckt werden. Bitte gesondert darauf hinweisen! Ich habe aus Versehen die Einheit zerlegt, ;-(
Das Foto mit Plektrum an der unteren Schmalseite zeigt dies sehr gut.
Danke für die Anleitung!
Nachdem ich in zwei Fachgeschäften mit meinem zerstörten Display abgewiesen wurde, habe ich mich, trotz völliger Unerfahrenheit auf elektron. Gebiet, selbst an die Arbeit gemacht. Da ich noch zur Billyregal-Aufbau-Generation gehöre, habe ich mit Hilfe dieser hervorragenden!!! Reparaturanweisung tatsächlich ein völlig zerstörtes Display ausgetauscht und halte jetzt ein “neues” funktionstüchtiges Smartphone in den Händen. Ein Lob an das Ifixit-Team und auch an Fairphone, die die Reparatur durch einfachen Aufbau möglich machen.
Angela 02.04.2021
Viel Spaß mit deinem selbst reparierten Fairphone! :)
More than a little frustrated, I followed this guide but unfortunately misunderstood that the edge of the screen was not the edge of the display module. Now I have a phone with a screen that falls out. The actual Fairphone site suggests just pushing the module out from the battery compartment, I'm wondering why this guide tries to make it so much more complex (and potentially damaging)?
Also, does anyone know the best way to reattach a Fairphone screen?
Super tuto, merci
Après une chute d’environ 1 mètre, écran vers le bas, avec la protection “coque complète, l’écran c’est “désolidarisé” du module écran (comme si à l’étape de glisser le médiator, on l’avait glissé dans la mauvais rainure).
Je n’ai pas pensé à prendre de photo.
L’effet occasionné est que, vers le bas de l’écran, quand on tapait avec le doigt, cela faisait un bruit et un décalage au click.
J’ai donc démonté le module écran, recollé la dalle au module écran avec de la colle rapide (attention, étape critique).
Après remontage, le décalage au click et le bruit avaient disparus.
Great tuto, thank's
After a 1 metter fall, screen bellow, with the full protective case, the screen was dissociate from the screen-board, like if at the mediator step, it was inserated in the wrong slit.
I sadly didn't take a pict.
The effect was a delay and a sound when I would to tuch the bottom of the screen.
I disassembled till the screen-board step, and then pasted with strong paste the screen on the screen module.
After reassembling, the delay an the sound disapeared.
Thanks a lot.
Vielen Dank für die gute Anleitung. Ich musste jetzt auch das Display tauschen. Soweit war das einfach machbar.
Nun habe ich allerdings folgendes Problem: Der Akku lädt nicht mehr (Das Fairphone sagt aber, dass es lädt)
Vielleicht habt ihr eine Idee?
Ich schätze, du hast den Akku sicherheitshalber nochmal rausgenommen und wieder eingesetzt?
Super tuto : si j'ai réussi, vous pouvez y arriver vous aussi.
Tut mir leid, aber bei mir hat's nicht geklappt. Eine Schraube hat sich nicht gelöst und das ganze Teil ist auseinandergebrochen. Da ist wohl noch einiges nachzuarbeitnen
Altijd blij met jullie, een vraag .. .het licht van mijn Fairphone 3 begint steeds vaker een beetje te knipperen...soms minder licht, en dan weer helderder. Wat is er loos, groet Ingrid
Is there any way to get a midframe? My phone dropped onto concrete pavement from the second floor, resulting in a shattered screen and broken midframe. Fixing it wouldn't be too big of a deal, however I can't seem to find a replacement midframe.
ist das Plektrum im Lieferumfang enthalten?
Is the pick included in the scope of delivery?
Wenn du das Display bestellst, bekommst du nur das Display. Die Fix Kits, in denen alles kommt, was du für die Reparatur brauchst, gibt es dafür noch nicht. Aber du kannst auch eine andere dünne Plastikkarte verwenden, statt des Plektrums.
