Ir para o conteúdo principal
Fairphone 3 Battery Replacement
O que você precisa
  1. Fairphone 3 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Fairphone 3 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
    Pergunte ao FixBot
    Comentar
  2. Fairphone 3 Battery Replacement: passo 2, imagem 1 %32 Fairphone 3 Battery Replacement: passo 2, imagem 2 %32 Fairphone 3 Battery Replacement: passo 2, imagem 3 %32
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    Pergunte ao FixBot
    Comentar
  3. Fairphone 3 Battery Replacement, Battery: passo 3, imagem 1 %32 Fairphone 3 Battery Replacement, Battery: passo 3, imagem 2 %32
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
    Pergunte ao FixBot
    Comentar
  4. Fairphone 3 Battery Replacement: passo 4, imagem 1 %32 Fairphone 3 Battery Replacement: passo 4, imagem 2 %32
    • Lift the battery out of its recess and remove it.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
17 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
259.028 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
122 Membros
Autoria de 25.842 guias
4Comentários do guia
Vielen Dank!
Einfach und direkt umgesetzt..
carola kamp - Responder Compartilhar
Imagine if all cellphone producers made it this easy :-)
Martin Andre Bae Pedersen - Responder Compartilhar
Anything to keep in mind, e.g. should I first give the phone a full charge once the new battery is installed?
Luke D - Responder Compartilhar
Where can I get the battery in Nigeria, if not how can I get one coz the one on my phone is weak
Mueez - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 25
Últimos 30 dias: 134
Ao todo: 12,281
