Ir para o conteúdo principal
Fairphone 2 Rear Camera Module Replacement
O que você precisa
  1. Fairphone 2 Rear Camera Module Replacement, Slim Case: passo 1, imagem 1 %32 Fairphone 2 Rear Camera Module Replacement, Slim Case: passo 1, imagem 2 %32 Fairphone 2 Rear Camera Module Replacement, Slim Case: passo 1, imagem 3 %32
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
    Pergunte ao FixBot
    Comentar
  2. Fairphone 2 Rear Camera Module Replacement: passo 2, imagem 1 %32 Fairphone 2 Rear Camera Module Replacement: passo 2, imagem 2 %32 Fairphone 2 Rear Camera Module Replacement: passo 2, imagem 3 %32
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
    Pergunte ao FixBot
    Comentar
  3. Fairphone 2 Rear Camera Module Replacement: passo 3, imagem 1 %32
    • Remove the front part of the slim case.
    Pergunte ao FixBot
    Comentar
  4. Fairphone 2 Rear Camera Module Replacement, Battery: passo 4, imagem 1 %32 Fairphone 2 Rear Camera Module Replacement, Battery: passo 4, imagem 2 %32 Fairphone 2 Rear Camera Module Replacement, Battery: passo 4, imagem 3 %32
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    Pergunte ao FixBot
    Comentar
  5. Fairphone 2 Rear Camera Module Replacement, Display Assembly: passo 5, imagem 1 %32 Fairphone 2 Rear Camera Module Replacement, Display Assembly: passo 5, imagem 2 %32 Fairphone 2 Rear Camera Module Replacement, Display Assembly: passo 5, imagem 3 %32
    • After taking out the battery you can unlock the display assembly.
    • Flip the two blue switches to the inner position.
    • Slide the display assembly towards the bottom of the phone.
    Pergunte ao FixBot
    Comentar
    • Another possible way of sliding the display assembly open.
    Pergunte ao FixBot
    Comentar
  6. Fairphone 2 Rear Camera Module Replacement: passo 7, imagem 1 %32
    • Take off the display assembly.
    Pergunte ao FixBot
    Comentar
  7. Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: passo 8, imagem 1 %32 Fairphone 2 Rear Camera Module Replacement, Rear Camera Module: passo 8, imagem 2 %32
    • Remove the three Phillips #0 screws of the module which are nicely marked by the blue circles.
    • Now the module should stand off a little bit due to the pogo pins underneath.
    Pergunte ao FixBot
    Comentar
  8. Fairphone 2 Rear Camera Module Replacement: passo 9, imagem 1 %32
    • Take out the whole module.
    Pergunte ao FixBot
    Comentar
Conclusão
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
71 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
133.784 Reputação
Autoria de 189 guias
Equipe
23Comentários do guia
Alles gut - hat wunderbar funktioniert, insbesondere dank des Videos für Schritt 4
Walter Strohschein - Responder Compartilhar
Heel snelle levering van mijn nieuwe camera!
Het was ons (mijn man) vast niet gelukt zonder de goede begeleidende filmpjes!
Betty Bol
Betty - Responder Compartilhar
die Variante mit slim case ist noch nicht berücksichtigt
Ansonsten: super Anleitung
W. Koch - Responder Compartilhar
Hat prima funktioniert dank einfacher Anleitung und einfacher Bauweise.
Christian Heider - Responder Compartilhar
Geschafft! - Schritt 4 war beim Slim Case nicht so einfach, aber nach ein paar Minuten hatte ich es raus. Ich frage mich bloss, was ich nun mit der alten Kamera mache..? Kann man die zurückschicken? Gibt es dazu irgendwelche Infos? Danke für die Anleitung und allfällige Infos bezüglich “Zukunft der alten Kamera” ;-) !
Claudia Serena Herrmann - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 56
Ao todo: 123,230
