Ir para o conteúdo principal
Introdução
Replacing the battery in your Fairphone 2 is easy and requires no tools.
Ferramentas
Nenhuma ferramenta especificada.
Peças
  1. Pick a corner of your slim case and get between the two parts with your thumb's fingernails. Pull up the back part of the slim case to separate the small snap fit connections. Remove the back part of the slim case.
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Get in between the front part of the slim case and the phone's body with your thumb nail. Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display. Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Remove the front part of the slim case.
    • Remove the front part of the slim case.
  4. Push the battery toward the top of the phone. Pull the battery out away from the phone. Pull the battery out away from the phone.
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
    It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
    It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
    Jim Kinnibrugh - Responder
Conclusão
6 outras pessoas concluíram este guia.
Tobias Isakeit
Membro desde: 31-03-2014
56.683 Reputation
120 Guias de autoria
iFixit Membro de iFixit
Community
107 Membros
9.591 Guias de autoria
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Past 24 Hours: 102
Past 7 Days: 622
Past 30 Days: 2,794
All Time: 97,683
