Ir para o conteúdo principal
Fairphone 2 Battery Replacement
O que você precisa
  1. Fairphone 2 Battery Replacement, Slim Case: passo 1, imagem 1 %32 Fairphone 2 Battery Replacement, Slim Case: passo 1, imagem 2 %32 Fairphone 2 Battery Replacement, Slim Case: passo 1, imagem 3 %32
    • Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
    • Pull up the back part of the slim case to separate the small snap fit connections.
    • Remove the back part of the slim case.
  2. Fairphone 2 Battery Replacement: passo 2, imagem 1 %32 Fairphone 2 Battery Replacement: passo 2, imagem 2 %32 Fairphone 2 Battery Replacement: passo 2, imagem 3 %32
    • Get in between the front part of the slim case and the phone's body with your thumb nail.
    • Separate the snap fit connectors on the front part by pulling it to the side and pushing against the display.
  3. Fairphone 2 Battery Replacement: passo 3, imagem 1 %32
    • Remove the front part of the slim case.
  4. Fairphone 2 Battery Replacement, Battery: passo 4, imagem 1 %32 Fairphone 2 Battery Replacement, Battery: passo 4, imagem 2 %32 Fairphone 2 Battery Replacement, Battery: passo 4, imagem 3 %32
    • Push the battery toward the top of the phone.
    • Pull the battery out away from the phone.
Conclusão
10 outras pessoas executaram este guia.
Tobias Isakeit
Membro desde: 03/31/14
130.877 Reputação
Autoria de 189 guias
Equipe
1Comentário do guia
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
Jim Kinnibrugh - Responder
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 14
Últimos 30 dias: 57
Ao todo: 133,572
