Ir para o conteúdo principal
FAO Schwarz Apex 1 Remote Control Battery Replacement
O que você precisa
  1. FAO Schwarz Apex 1 Remote Control Battery Replacement, Remote Control Battery: passo 1, imagem 1 %32
    • Remove the plastic battery cover to get at the battery compartment.
    • The cover can be removed by pressing down on the lever and sliding.
  2. FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 2, imagem 1 %32 FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 2, imagem 2 %32 FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 2, imagem 3 %32
    • Remove the dead battery, being careful not to damage the internal battery connectors.
    • The battery is a bit wedged in there, so you'll have to press hard to pop it out.
  3. FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 3, imagem 1 %32 FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 3, imagem 2 %32 FAO Schwarz Apex 1 Remote Control Battery Replacement: passo 3, imagem 3 %32
    • Insert the new 6F22 9 volt battery.
    • Line up the positive icons on the battery with the positive icons in the battery compartment.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 516
