Ir para o conteúdo principal
Explorer One HD Wifi Camera Battery Replacement
O que você precisa
  1. Explorer One HD Wifi Camera Battery Replacement, Battery: passo 1, imagem 1 %32
    • Position the camera with the bottom panel facing up
  2. Explorer One HD Wifi Camera Battery Replacement: passo 2, imagem 1 %32
    • Use the 000 size Philips screw head
  3. Explorer One HD Wifi Camera Battery Replacement: passo 3, imagem 1 %32
    • Carefully unscrew the panel
  4. Explorer One HD Wifi Camera Battery Replacement: passo 4, imagem 1 %32
    • If you need, use the flathead driver to pry off the cover.
    • If not, simply pull off the panel
  5. Explorer One HD Wifi Camera Battery Replacement: passo 5, imagem 1 %32
    • Once the battery is exposed, simply pull the battery out.
    • You may have to wiggle the battery to pull it out.
  6. Explorer One HD Wifi Camera Battery Replacement: passo 6, imagem 1 %32
    • The battery is connected the camera by terminals for ease of removal
    • Be sure to keep the battery and camera clean during this step
  7. Explorer One HD Wifi Camera Battery Replacement: passo 7, imagem 1 %32
    • push the battery back into the housing gently
Conclusão
Now, your camera is as good as new, have fun!
3 outras pessoas executaram este guia.
Cameron Smith
Membro desde: 03/17/22
400 Reputação
Autoria de 2 guias
Equipe
Colorado Fixers Membro de Colorado Fixers
Community
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 32
Duração total: 409
