Ir para o conteúdo principal
ExoPC Slate Back Cover and Shield Replacement
O que você precisa
  1. ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: passo 1, imagem 1 %32 ExoPC Slate Back Cover and Shield Replacement, Back Cover and Shield: passo 1, imagem 2 %32
    • Turn the PC on its back with the screen facing down and pull on the piece of plastic shown in the image. Use your fingernails to prod into the depression where the two plastic covers meet.
  2. ExoPC Slate Back Cover and Shield Replacement: passo 2, imagem 1 %32 ExoPC Slate Back Cover and Shield Replacement: passo 2, imagem 2 %32
    • Using the 00 Phillips screwdriver remove the two screws in the corners.
    • Using your left hand pull at the exposed section of the PC while simultaneously pushing the right with the thumb of your other hand. This will release the plastic clips allowing back cover to slide off, as shown from the picture
    • When removing the back cover make sure that the ribbon connectors going to the screen are not damaged. Carefully fold over the cover like a book.
  3. ExoPC Slate Back Cover and Shield Replacement: passo 3, imagem 1 %32 ExoPC Slate Back Cover and Shield Replacement: passo 3, imagem 2 %32 ExoPC Slate Back Cover and Shield Replacement: passo 3, imagem 3 %32
    • Remove the tape covering the metal shield.
    • Remove the 12 screws using the Phillips #00 screwdriver.
    • Dislodge the shield by pulling the prongs away from underneath the battery. The shield should come completely off.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathon Cronin
Membro desde: 10/29/18
337 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Ao todo: 516
