Introdução
This guide walks you through removing the Eureka SuctionSeal 2.0 Pet vacuum's motor. You may find this guide useful if you are experiencing poor suction. This guide requires physical strength to follow so it is recommended that owners attempt to resolve issues through the troubleshooting page before using this guide.
O que você precisa
Place the device upright with the brush roller closest to you.
Pull up on the latch at the top of the dust cup.
Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
Locate the gray exhaust filter cover at the top of the vacuum's base.
Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
Lift the cover away from the vacuum.
Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
Remove the two 20mm screws using a JIS 1 screwdriver.
Grab the brush roll on both ends.
Lift up on the right side of the brush roll.
Lift up on the left side of the brush roll, completely removing it from its frame.
Separate the brush roll from the belt and remove the brush roll from the vacuum.
Rotate the belt until the front is above the motor shaft.
Twist the belt away from you, allowing the narrow side of the belt to slip between the motor shaft and the vertical rod.
Separate the belt from the motor shaft.
Rotate the motor cover upright until you hear the foot pedal click and the cover won't rotate in either direction.
Remove the bottom exhaust filter.
Use a 3.0 hex bit screwdriver to remove the two 20mm screws on the top of the dust cup stand.
Remove the dust cup stand.
Flip the vacuum so that it is right side up again with the front of the motor cover facing you.
Insert either a metal spudger or a plastic opening tool into the right or left side of the cover seam.
Pry upward as you move the tool across the cover, separating the top half of the motor cover from the lower half.
