Ir para o conteúdo principal
Eureka SuctionSeal 2.0 Pet Filters Replacement
  1. Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: passo 1, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Filters Replacement, Dust Cup: passo 1, imagem 2 %32
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: passo 2, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Filters Replacement, Filters: passo 2, imagem 2 %32
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate it counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 3, imagem 1 %32
    • Grab the tab on the exhaust filter.
    • Lift the filter straight up from the vacuum's base.
  4. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 4, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 4, imagem 2 %32
    • Locate the lid at the top of the previously removed dust cup.
    • Lift the latch and lay the cover back.
  5. Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 5, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Filters Replacement: passo 5, imagem 2 %32
    • Pull up on the tag and remove the filter.
Conclusão
Anna Snyder
Membro desde: 10/02/17
336 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S4-G5, Livingston Fall 2017 Membro de Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 605
