Ir para o conteúdo principal
Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement
O que você precisa
  1. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: passo 1, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Dust Cup: passo 1, imagem 2 %32
    • Place the device upright with the brush roller closest to you.
    • Pull up on the latch at the top of the dust cup.
    • Tilt the top of the dust cup forward and pull towards yourself, removing the container from the device.
  2. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: passo 2, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Brush Roll Cover: passo 2, imagem 2 %32
    • Locate the gray exhaust filter cover at the top of the vacuum's base.
    • Grip the two tabs in the middle of the filter cover and rotate counter-clockwise.
    • Lift the cover away from the vacuum.
  3. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 3, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 3, imagem 2 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 3, imagem 3 %32
    • Pull up and unhook the two front tower latches using two fingers. These are located at the base of the tower.
    • Pull up and unhook the latch on the back of the tower.
    • Firmly lift the vacuum tower up and out of its stand.
    • The exhaust filter cover can be replaced once the tower is removed. It will not affect the steps.
  4. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 4, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 4, imagem 2 %32
    • Remove the four 20mm screws on the top of the vacuum head's cover using a JIS 1 screwdriver.
  5. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 5, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 5, imagem 2 %32
    • Turn the vacuum head so that the back is facing you.
    • Press the handle release pedal.
    • Rotate the top of the motor cover down while pressing on the pedal release.
    • The motor cover should rotate from an upright position back towards the ground, as it would if the handle were still attached.
  6. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 6, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 6, imagem 2 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 6, imagem 3 %32
    • Locate the two tabs on the back of the cover.
    • Pull up on the tabs and lift the cover away from the device.
  7. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: passo 7, imagem 1 %32 Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement, Belt Latch Assembly: passo 7, imagem 2 %32
    • Locate the belt latch assembly. It will be on your right when the brush roll is facing you.
    • Remove the two 20mm screws using a JIS 1 screwdriver.
  8. Eureka SuctionSeal 2.0 Pet Belt Latch Assembly Replacement: passo 8, imagem 1 %32
    • Lift up on the belt latch assembly and remove it from the vacuum.
Conclusão
Equipe
Cal Poly, Team S4-G5, Livingston Fall 2017 Membro de Cal Poly, Team S4-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G5
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 848
