Introdução
The roller can get worn out over time. Therefore, it’s important to know how to replace it. This guide will cover the steps necessary to successfully replace the roller. Make sure your vacuum is off before attempting to replace the roller.
O que você precisa
Unscrew the two 18.1 mm PH2 Phillips head screws on the bottom of the vacuum.
Pull the roller, motor, and belt out of the casing.
Separate the roller from the belt.
Quase terminado!
Conclusão
