Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If you determine that your vacuum is no longer picking up debris, is hard to push, or brush roll will not turn, this guide will help you to replace the belt.
O que você precisa
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
8 outras pessoas executaram este guia.
5 comentários
It was Too hard So went to stretch the belt then it was on
To reassemble was not available for me so I kind of did it myself but I'm having trouble getting it back on straight
i have read every sticker on this vbacuum read several maintenance steps …. i mean DA remove four screws …huh.
now can someone tell me whart size belt to get from the store
Sara Leinen
sparkplugkitten@msn.com
I got it used. I turned it on it worked. Then it just turned off and want come back on some please help me
Where's the trouble shooting
