Introdução
If the accessory holder is no longer able to hold the multiple tools associated with the vacuum, this guide outlines the its replacement.
O que você precisa
On the back of the vacuum, pull the handle connected to the hose away from the vacuum.
Using a T15 Torx Security Screwdriver, remove the screw on each side of the indention in which the hose normally rests.
Uma outra pessoa concluiu este guia.
