Introdução
If you determine that your vacuum brush roll will not turn and produces a burning smell, this guide will help you to replace the brush roll.
O que você precisa
Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
6 outras pessoas executaram este guia.
Um comentário
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
