Ir para o conteúdo principal
Eureka AirSpeed Bagless Zuum Brush Roll Replacement
O que você precisa
  1. Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: passo 1, imagem 1 %32 Eureka AirSpeed Bagless Zuum Brush Roll Replacement, Brush Roll: passo 1, imagem 2 %32
    • Step on the grey release button located between the two back wheels to lower the handle flat to the floor.
    • Insure the vacuum is unplugged before starting the process of removing the brush roll.
  2. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 2, imagem 1 %32
    • Using a Phillips #2 screwdriver, remove the four screws from each corner of the brush roll cover.
  3. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 3, imagem 1 %32 Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 3, imagem 2 %32
    • Remove the brush cover from the vacuum base, by pulling straight up.
  4. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 4, imagem 1 %32
    • Firmly press upwards from below the brush roll on the side opposite the belt.
  5. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 5, imagem 1 %32
    • After one end is displaced, remove the other side by pressing firmly upwards from below the the brush roll.
  6. Eureka AirSpeed Bagless Zuum Brush Roll Replacement: passo 6, imagem 1 %32
    • Once the brush roll is displaced from the base, detach the belt from the brush roll in order to clean the brush roll.
Conclusão
6 outras pessoas executaram este guia.
Celina Burchett
Membro desde: 10/13/14
1.122 Reputação
Autoria de 8 guias
Equipe
Clemson, Team 2-2, Benson Fall 2014 Membro de Clemson, Team 2-2, Benson Fall 2014
CLEM-BENSON-F14S2G2
Membros da 4
Autoria de 18 guias
Um comentário
Brush roll replacement is a no brainer. It is the brush roll assembly that turns the brush that I need to fix. Cannot determine what tool to use as it doesn't come off using a regular screwdriver and eureka won't tell me what to ese.
Tami Jones - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 12,029
