Ir para o conteúdo principal
Eureka 1660SP Roller Replacement
O que você precisa
  1. Eureka 1660SP Roller Replacement, Roller: passo 1, imagem 1 %32 Eureka 1660SP Roller Replacement, Roller: passo 1, imagem 2 %32
    • Press the black separator switch and lightly pull the bottom half away from the top.
  2. Eureka 1660SP Roller Replacement: passo 2, imagem 1 %32 Eureka 1660SP Roller Replacement: passo 2, imagem 2 %32
    • Remove the vacuum head from the lower half of the body.
  3. Eureka 1660SP Roller Replacement: passo 3, imagem 1 %32 Eureka 1660SP Roller Replacement: passo 3, imagem 2 %32 Eureka 1660SP Roller Replacement: passo 3, imagem 3 %32
    • Turn the vacuum head wheels up and remove all seven 13.9mm screws from the bottom using a #2 Phillips head screwdriver.
    • Separate the top and bottom of the vacuum head. Set the top aside.
  4. Eureka 1660SP Roller Replacement: passo 4, imagem 1 %32 Eureka 1660SP Roller Replacement: passo 4, imagem 2 %32
    • Turn the vacuum head's bottom over so that the inside of the head is facing up.
    • Using a Phillips #00 screwdriver, press down on metal bar of the roller on one side until it releases from the housing.
    • Turn the vacuum head's bottom over and pull at the roller and bar until they are completely out of the housing.
  5. Eureka 1660SP Roller Replacement: passo 5, imagem 1 %32
    • Press the new bar and roller into place.
    • Replace the screws.
Linha de Chegada
Equipe
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 440
