Ir para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Before you start, make sure your vacuum is unplugged the power outlet. Press and hold down the black button below the handle while pulling the pole out.
    • Before you start, make sure your vacuum is unplugged the power outlet.
    • Press and hold down the black button below the handle while pulling the pole out.
  2. Press the black separator switch to separate the top and bottom halves of the vacuum. Press the black separator switch to separate the top and bottom halves of the vacuum.
    • Press the black separator switch to separate the top and bottom halves of the vacuum.
  3. Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown. Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing. Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
    • Use a #2 Phillips head screwdriver to remove six 13.9mm screws from the side of the motor housing (top half) as shown.
    • Remove two 14.1mm screws from the front face of the housing. You are now all set to open the housing.
    • Keep a watchful eye on the two screws from the front face. These two have additional collars to their necks and will not fit in any of the other holes, yet no other screw will fit in their spots without the collar.
  4. Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
    • Once the housing is open, locate the solid chrome plated piece at the front end of the extendable pole.
  5. On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing. Re-insert the chrome plated piece into the center track.
    • On the side of the motor housing which does not hold the engine, find the center track which runs along the inside of the housing.
    • Re-insert the chrome plated piece into the center track.
Conclusão
Uma outra pessoa concluiu este guia.
Evan Fodi
Membro desde: 24/09/2013
122 Reputação
2 Guias de autoria
Equipe
UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 1-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S1G1
3 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 388
