Introdução
This guide is for the Euhomy IM-06D icemaker. This guides purpose is to replace the power supply cable. This part provides the power for the icemaker. Symptoms that mean this part may need to be replaced are the device not turning on or not staying on for long periods of time. Please make sure to unplug the device before starting all guides.
O que você precisa
Rotate the device so that the screws on the bottom are visible.
Remove the two 15 mm Phillips screws.
Remove the two 10 mm Phillips screws.
Follow the green ground wire and remove the 15 mm screw securing it with a Phillips screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
