Ir para o conteúdo principal
Eufy RoboVac 11S Filters Replacement
O que você precisa
  1. Eufy RoboVac 11S Filters Replacement, Filters: passo 1, imagem 1 %32 Eufy RoboVac 11S Filters Replacement, Filters: passo 1, imagem 2 %32
    • Press the dust collector release button.
    • Pull the dust collector out.
  2. Eufy RoboVac 11S Filters Replacement: passo 2, imagem 1 %32 Eufy RoboVac 11S Filters Replacement: passo 2, imagem 2 %32
    • Push the blue button up and open the dust collector.
    • Empty the dust collector, and throw all the dust into the trash bin.
  3. Eufy RoboVac 11S Filters Replacement: passo 3, imagem 1 %32 Eufy RoboVac 11S Filters Replacement: passo 3, imagem 2 %32 Eufy RoboVac 11S Filters Replacement: passo 3, imagem 3 %32
    • Pull the hooks up to take out the pre-filter.
    • Pull the filter lightly because the hook by the filter is easy to break.
  4. Eufy RoboVac 11S Filters Replacement: passo 4, imagem 1 %32 Eufy RoboVac 11S Filters Replacement: passo 4, imagem 2 %32 Eufy RoboVac 11S Filters Replacement: passo 4, imagem 3 %32
    • Take out the high-performance filter to the side and use a cleaning brush to clean the filter.
    • Take out the foam filter to the side and dispose of it in the trash bin.
  5. Eufy RoboVac 11S Filters Replacement: passo 5, imagem 1 %32
    • Use the cleaning brush to sweep the dust from the pre-filter.
  6. Eufy RoboVac 11S Filters Replacement: passo 6, imagem 1 %32 Eufy RoboVac 11S Filters Replacement: passo 6, imagem 2 %32
    • Put the pre-filter back in the dust collector.
    • Use your finger to push the top button first.
    • Push the filter lightly because the hook by the filter is easy to break.
  7. Eufy RoboVac 11S Filters Replacement: passo 7, imagem 1 %32 Eufy RoboVac 11S Filters Replacement: passo 7, imagem 2 %32
    • Open the back of the dust collector.
    • Replace the white foam filter.
    • Put the black high-performance filter at the top of the foam filter.
    • Make sure to put the foam filter before the high-performance filter, otherwise the robot will have problems cleaning.
Conclusão
felix
Membro desde: 05/13/20
181 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 23
Últimos 30 dias: 83
Duração total: 4,792
