Introdução
Prerequisite Only
O que você precisa
Pull the plastic tab on the battery compartment cover panel to loosen it, then pull the panel off.
Use the T10 hexagonal tip from the iFixit Bit Driver Kit or comparable tool to remove the two 22 mm hexagonal screws on the front face of the device.
Unplug all the component socket connections from the motherboard as shown in the image.
Uma outra pessoa concluiu este guia.
