Ir para o conteúdo principal
Etekcity Lasergrip 1080 Battery Replacement
  1. Etekcity Lasergrip 1080 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Pull the battery cover away from the handle by gripping near the thumb groove.
  2. Etekcity Lasergrip 1080 Battery Replacement: passo 2, imagem 1 %32
    • Gently pull the battery out of the handle.
    • Excessive force could damage wires.
  3. Etekcity Lasergrip 1080 Battery Replacement: passo 3, imagem 1 %32 Etekcity Lasergrip 1080 Battery Replacement: passo 3, imagem 2 %32
    • Disconnect the battery by pulling the connector away from it.
    • Positive first
    • Negative second
    • When replacing the battery, this order is reversed.
Conclusão
Equipe
USF Tampa, Team 5-1, Blackwell Fall 2015 Membro de USF Tampa, Team 5-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G1
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 37
Últimos 30 dias: 126
Duração total: 6,378
