Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
  1. Your device should look like this. Your device should look like this. Your device should look like this.
    • Your device should look like this.
  2. Turn the unit on its side and look for this panel.
    • Turn the unit on its side and look for this panel.
  3. Unscrew this screw with a Phillips head #0 screwdriver. Remove the panel. Remove the panel.
    • Unscrew this screw with a Phillips head #0 screwdriver.
    • Remove the panel.
  4. Pull out the battery and disconnect the connector. Pull out the battery and disconnect the connector. Pull out the battery and disconnect the connector.
    • Pull out the battery and disconnect the connector.
Conclusão
To reassemble your device, follow these instructions in reverse order, and remember to connect the connector when putting in a new battery.
Uma outra pessoa concluiu este guia.
Levi G
Membro desde: 13/07/2018
2.678 Reputação
20 Guias de autoria
What specific battery did you purchase to replace the original battery pack? My battery needs to be 1.25” by 1.25” to fit into the compartment. Many of the batteries I have found on Amazon that claim to be replacement are much larger an won’t fit into the compartment.
Mark Chapin - Responder
https://www.amazon.com/South-33053-Cordl...
This battery seems to be a good fit. It says in the question and answer section that it’s 1.2"" x 1.15"x 0.42".
Levi G -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 142
