Ir para o conteúdo principal
Etón Scorpion Battery Replacement
O que você precisa
  1. Etón Scorpion Battery Replacement, Battery: passo 1, imagem 1 %32 Etón Scorpion Battery Replacement, Battery: passo 1, imagem 2 %32 Etón Scorpion Battery Replacement, Battery: passo 1, imagem 3 %32
    • Your device should look like this.
  2. Etón Scorpion Battery Replacement: passo 2, imagem 1 %32
    • Turn the unit on its side and look for this panel.
  3. Etón Scorpion Battery Replacement: passo 3, imagem 1 %32 Etón Scorpion Battery Replacement: passo 3, imagem 2 %32 Etón Scorpion Battery Replacement: passo 3, imagem 3 %32
    • Unscrew this screw with a Phillips head #0 screwdriver.
    • Remove the panel.
  4. Etón Scorpion Battery Replacement: passo 4, imagem 1 %32 Etón Scorpion Battery Replacement: passo 4, imagem 2 %32 Etón Scorpion Battery Replacement: passo 4, imagem 3 %32
    • Pull out the battery and disconnect the connector.
Conclusão
To reassemble your device, follow these instructions in reverse order, and remember to connect the connector when putting in a new battery.
Uma outra pessoa concluiu este guia.
9021007
Membro desde: 07/13/18
4.599 Reputação
Autoria de 25 guias
3 comentários
What specific battery did you purchase to replace the original battery pack? My battery needs to be 1.25” by 1.25” to fit into the compartment. Many of the batteries I have found on Amazon that claim to be replacement are much larger an won’t fit into the compartment.
Mark Chapin - Responder
https://www.amazon.com/South-33053-Cordl...
This battery seems to be a good fit. It says in the question and answer section that it’s 1.2"" x 1.15"x 0.42".
9021007 -
Need to switch the wire positions. What's the best way?
David - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 1,105
