Ir para o conteúdo principal
Introdução
Sometimes the outer case of the device can become cracked or damaged. This guide will show you how to remove the outer case.
Peças
Nenhum componente especificado.
  1. Inser the flat end of a spudger into one of the two notches and pry off the case. Inser the flat end of a spudger into one of the two notches and pry off the case.
    • Inser the flat end of a spudger into one of the two notches and pry off the case.
  2. Slide the spudger around the perimeter of the radar housing until the case separates. Slide the spudger around the perimeter of the radar housing until the case separates.
    • Slide the spudger around the perimeter of the radar housing until the case separates.
  3. Repeat these steps to remove the other side. Repeat these steps to remove the other side.
    • Repeat these steps to remove the other side.
Conclusão
To reassemble your device, simply place the pieces in their original places, and gently snap them closed.
Uma outra pessoa concluiu este guia.
Kelsey Ferrenberg
Membro desde: 12/04/2018
710 Reputação
4 Guias de autoria
Equipe
UW Tacoma, Team S1-G1, Liner Spring 2018 Membro de UW Tacoma, Team S1-G1, Liner Spring 2018
UWT-LINER-S18S1G1
5 Membros
4 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 254
