Introdução
Are the buttons on your Escort Radar 9500IX's cracked or jammed? If this is the case, then follow this guide to replace the buttons on your radar.
O que você precisa
Carefully pry the grey frame off the black plastic covering using the nylon spudger.
Quase terminado!
Conclusão
Um comentário
Ummm where/how do you get the replacement buttons. Mine are just simply non legible from wear and tear, yet still works perfectly.
