Ir para o conteúdo principal
Escort Passport 9500IX Button Board Replacement
O que você precisa
  1. Escort Passport 9500IX Button Board Replacement, Back Panel: passo 1, imagem 1 %32
    • Remove the three 1.2 mm Phillips #1 screws on the back of the device.
  2. Escort Passport 9500IX Button Board Replacement: passo 2, imagem 1 %32
    • Pry off the back panel of the radar using the nylon spudger.
  3. Escort Passport 9500IX Button Board Replacement, Buttons: passo 3, imagem 1 %32 Escort Passport 9500IX Button Board Replacement, Buttons: passo 3, imagem 2 %32 Escort Passport 9500IX Button Board Replacement, Buttons: passo 3, imagem 3 %32
    • Carefully pry the grey frame off the black plastic covering using the nylon spudger.
  4. Escort Passport 9500IX Button Board Replacement: passo 4, imagem 1 %32 Escort Passport 9500IX Button Board Replacement: passo 4, imagem 2 %32
    • Slowly peel the buttons off the button board.
  5. Escort Passport 9500IX Button Board Replacement, Button Board: passo 5, imagem 1 %32 Escort Passport 9500IX Button Board Replacement, Button Board: passo 5, imagem 2 %32 Escort Passport 9500IX Button Board Replacement, Button Board: passo 5, imagem 3 %32
    • Detach the orange flap on the motherboard.
    • Carefully remove the motherboard from the grey plastic frame.
  6. Escort Passport 9500IX Button Board Replacement: passo 6, imagem 1 %32
    • Detach the orange flap directly behind the button board.
  7. Escort Passport 9500IX Button Board Replacement: passo 7, imagem 1 %32 Escort Passport 9500IX Button Board Replacement: passo 7, imagem 2 %32 Escort Passport 9500IX Button Board Replacement: passo 7, imagem 3 %32
    • Carefully pull out the button board from the grey frame.
Conclusão
Kennedy Morales
Membro desde: 10/20/17
655 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S2-G3, Peak Fall 2018 Membro de UMass Dartmouth, Team S2-G3, Peak Fall 2018
UMASSD-PEAK-F18S2G3
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 537
