Introdução
In this 13-step guide, I will show you how to replace the minute, hour and second hands on a clock.
First, you must remove the back of the clock.
Second you must remove parts of the clock's inner apparatus.
Last, you must remove the clock's entire inner apparatus from its golden cover in order to remove the hands.
O que você precisa
Using a Phillips screwdriver, remove the top screw.
Repeat for other two screws located on the lower right and left sides of the clock.
Place fingers on ridge around back plate and pull upward.
Using a Phillips screwdriver, remove the silver base located on top of cellinoid in upper right hand of inner clock.
Cellinoid is located below Silver Base. Remove Cellinoid with your fingers and pull it up from the inner clock apparatus.
Remove the bottom legs of the clock by unscrewing them with your fingers.
Caution: you may need to use a pair of pliers if bottom legs are attached too tight.
Using your hands, unscrew top screw located on top of the right bell.
Caution: You may need to use a pair of pliers to loosen the screw.
Repeat Directions in Step 6 but on the left bell screw.
Caution: You may need to use a pair of pliers.
After you remove the screws for both bells, both of the two bells and the bar connecting the two bells will easily come off. Remove these three components with your fingers.
Using your hand, remove the entire black, inner apparatus of clock. The golden ridge of the clock is attached to the glass screen.
In the front of the clock apparatus are the twelve numbers, minute hand, second hand, and hour hand.
Using a pair of tweezers, remove the golden peg in the center of the clock. This attaches the minute, hour and second hands.
After you have removed the golden peg, use the pair of tweezers to remove hour, minute and second hands.
3 outras pessoas executaram este guia.
