Ir para o conteúdo principal
Equity Alarm Clock 13014 Clock Bell Hammer Replacement
O que você precisa
  1. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, imagem 1 %32 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, imagem 2 %32 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock: passo 1, imagem 3 %32
    • Using a Phillip's Screwdriver, remove the three screws on the back cover of the clock.
    Pergunte ao FixBot
  2. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Back Cover of Clock (2): passo 2, imagem 1 %32
    • Using your hands, remove the back cover of the clock by grasping it and pulling it upwards.
    Pergunte ao FixBot
  3. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: passo 3, imagem 1 %32 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Cellinoid Cover: passo 3, imagem 2 %32
    • Using a Phillips Screwdriver, remove the Cellinoid Cover from inner clock apparatus.
    Pergunte ao FixBot
  4. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: passo 4, imagem 1 %32 Equity Alarm Clock 13014 Clock Bell Hammer Replacement, Bell Hammer: passo 4, imagem 2 %32
    • Using your fingers, remove the bell hammer from the inner apparatus of clock.
    Pergunte ao FixBot
  5. Equity Alarm Clock 13014 Clock Bell Hammer Replacement, You are Finished: passo 5, imagem 1 %32
    • Remove the clock's bell hammers and you are finished. Be sure to replace the old bell hammers with new ones.
    • Starting from Step 5, repeat each previous step to reassemble the clock.
    Pergunte ao FixBot
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 94
Ao todo: 4,210
