Ir para o conteúdo principal
Epson VS250 Speaker Replacement
O que você precisa
  1. Epson VS250 Speaker Replacement, Shell: passo 1, imagem 1 %32
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Using the Phillips #1 screwdriver, to loosen the screw on the top right corner of the projector. The screw only needs to be loosened.
  2. Epson VS250 Speaker Replacement: passo 2, imagem 1 %32
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Speaker Replacement: passo 3, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the three 6 mm screws that hold the side portion of the projector in place.
    • Use the same Phillips #1 screwdriver to remove the single 10 mm screw that is holding the side cover of the projector in place.
  4. Epson VS250 Speaker Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws that are holding the side cover of the projector in place.
  5. Epson VS250 Speaker Replacement: passo 5, imagem 1 %32 Epson VS250 Speaker Replacement: passo 5, imagem 2 %32
    • Flip the projector so that it lays upside down.
    • Using a Phillips #1 screwdriver, remove the eight 10 mm screws that secure the side portion of the projector.
  6. Epson VS250 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the front cover from the projector by pulling it off of the device.
  7. Epson VS250 Speaker Replacement: passo 7, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws.
    • After completing this step you will be able to remove the back cover from the projector.
  8. Epson VS250 Speaker Replacement: passo 8, imagem 1 %32
    • Slowly lift up the top shell up and out of the device.
    • Disconnect the ribbon cable from the motherboard and remove the shell from the device.
  9. Epson VS250 Speaker Replacement, Speaker: passo 9, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm screws holding the speaker in place.
  10. Epson VS250 Speaker Replacement: passo 10, imagem 1 %32 Epson VS250 Speaker Replacement: passo 10, imagem 2 %32
    • Pinch and unplug the speaker cable from the motherboard.
    • Remove the speaker from the device.
Conclusão
Warren Cutlip
Membro desde: 09/28/21
604 Reputação
Autoria de 5 guias
Equipe
Clemson, Team 4-2, Hunter Fall 2021 Membro de Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 112
