Ir para o conteúdo principal
Epson VS240 Shell Replacement
O que você precisa
  1. Epson VS240 Shell Replacement, Shell: passo 1, imagem 1 %32 Epson VS240 Shell Replacement, Shell: passo 1, imagem 2 %32 Epson VS240 Shell Replacement, Shell: passo 1, imagem 3 %32
    • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
    • The captive screw will loosen, but it cannot be fully removed.
    • Slide the panel off and remove it from the device.
  2. Epson VS240 Shell Replacement: passo 2, imagem 1 %32 Epson VS240 Shell Replacement: passo 2, imagem 2 %32
    • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
    • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
  3. Epson VS240 Shell Replacement: passo 3, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
  4. Epson VS240 Shell Replacement: passo 4, imagem 1 %32
    • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
    • Remove the white back plate from the device.
  5. Epson VS240 Shell Replacement: passo 5, imagem 1 %32 Epson VS240 Shell Replacement: passo 5, imagem 2 %32 Epson VS240 Shell Replacement: passo 5, imagem 3 %32
    • Flip the projector over so that the underside (side with the feet) is facing you.
    • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
    • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
    • You may need to use a screwdriver extender to reach the single screw.
  6. Epson VS240 Shell Replacement: passo 6, imagem 1 %32 Epson VS240 Shell Replacement: passo 6, imagem 2 %32 Epson VS240 Shell Replacement: passo 6, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
    • You may need to use a screwdriver extender to reach the two screws.
    • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
  7. Epson VS240 Shell Replacement: passo 7, imagem 1 %32 Epson VS240 Shell Replacement: passo 7, imagem 2 %32
    • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
    • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
    • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
Conclusão
Gerard Huber
Membro desde: 09/28/21
374 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 5-3, Hunter Fall 2021 Membro de Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 222
