Ir para o conteúdo principal
Epson Stylus Photo 820 Ink Cartridges Replacement
  1. Epson Stylus Photo 820 Ink Cartridges Replacement, Ink Cartridges: passo 1, imagem 1 %32
    • When you are low on ink your green power light will be flashing and your error light will stay a solid red.
  2. Epson Stylus Photo 820 Ink Cartridges Replacement: passo 2, imagem 1 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 2, imagem 2 %32
    • Lift the printer window open by pulling up on the tab.
    • Your printer should now be in the same state as shown in the second picture.
  3. Epson Stylus Photo 820 Ink Cartridges Replacement: passo 3, imagem 1 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 3, imagem 2 %32
    • Press the button on the far right to get your ink cartridge holders to slide over. (See the second picture)
  4. Epson Stylus Photo 820 Ink Cartridges Replacement: passo 4, imagem 1 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 4, imagem 2 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 4, imagem 3 %32
    • Press the tabs with the upward facing arrows to open the hatches as shown in the first picture.
    • Remove the ink cartridge(s) that needs to be replaced. The black cartridge is on the left and the color cartridge is on the right.
    • Make sure your cartridges are the same as the ones shown in the third picture. Non-Epson ink cartridges may not be recognized by your printer.
  5. Epson Stylus Photo 820 Ink Cartridges Replacement: passo 5, imagem 1 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 5, imagem 2 %32 Epson Stylus Photo 820 Ink Cartridges Replacement: passo 5, imagem 3 %32
    • Insert your new ink cartridges and close the hatches.
    • Close your printer door and push the ink cartridge button on the far right and again.
    • After your ink charges you're ready to print!
Linha de Chegada
Uma outra pessoa concluiu este guia.
Alex Lin
Membro desde: 04/10/11
99 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 20-68, Walters Spring 2011 Membro de Cal Poly, Team 20-68, Walters Spring 2011
CPSU-WALTERS-S11S20G68
Membros da 4
Autoria de 12 guias
Um comentário
I pushed the 3rd button so the cartridge holder will slide over, it will not move.
I tried unplugging the printer and plugging it back in & repower it up. still 'stuck' to the right.
I need to change the black ink. can you help? thank you!
tina - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 2,886
